1 - 2 of 2 Posts
I have a 6MGE with some oil leaks and it's showing low oil pressure, probably about 1/2-3/4 between L and half. I know the best thing to do is pull the engine and replace all the gaskets and seals of course, but I'm not in the position to do that at the moment. I've heard of guys running 10w30, 10w40, even 15w40 diesel oil and 20w50 etc. What oil out there would you recommend for my situation and maybe even help with the leaks a bit? I live in Canada but don't drive it in the winter at all, so it's only running in warmer weather. Thanks
Discussion Starter #2
Previous owner used Castrol 10w30 but Im thinking of switching to a thicker oil to help the leaks and oil pressure, what do you guys think? I'll be doing the oil change within the next month since I'm putting the car back on the road in April or so.
1 - 2 of 2 Posts
