1 - 3 of 3 Posts
I got a little aggressive trying to pry off the oil pan. I used a flat head screw driver in a few places and lightly pried and ended up putting a few small gouges and knicks on the block mounting surface. Is this anything to worry about? I would think the FIPG would just fill into these small areas. But I do NOT want to get this all back together and have it leak again. Which is the reason I pulled it off in the first place.
One idea I had to fill in the imperfections is put a small amount of JB weld to fill in those areas and then lightly sand it smooth.
Thoughts?!!
Bicycle part Rim Gas Automotive tire Automotive wheel system
Wood Sleeve Grey Tints and shades Automotive tire
Wood Rim Bicycle part Tints and shades Auto part
Wood Gas Engineering Metal Composite material
That's nothing. FIPG black will seal it no problem.
Notice the space at the mating sections, and the punched-in numbers from factory...
Comparable in size to your scratches.
FIPG will take care of them.
1 - 3 of 3 Posts
