1 - 6 of 6 Posts
Do they have to be torqued?
i searched for the answer here on CS.com so no FLAMING me for not searching! :lol:
· Founding Member
Lacking a micro torque wrench, I have always found that hand-tight with a small 1/4" drive ratchet is sufficient. And I don't mean body-builder, he-man hand-tight, just snug it down doing your best to apply equal effort to each bolt. If you are re-tightening or if you have the gasket then you have to be extra careful not to over-tighten as doing so could distort the flange and cause it not to seal properly. I've asked Santa for an in-lb torque wrench several xmas's but I guess the elves don't know how to make those (they are damned expensive).
Phil D.
the small bolts holding the oil pan to the block should be torqued to approx. 69 inch-pounds of torque. I believe that is approx. 5&3/4 foot-lb.
( not much at all )
1 - 6 of 6 Posts
