1 - 7 of 7 Posts
The passenger headlight goes up and down line a champ. The driver light goes up but not down when I use the light switch. I tested the motor straight to the battery and it works fine both up and down. Does anyone have any suggestions?
Discussion Starter #4
Thanks! I checked the retract relay and it is defective. Now I just have to find one that works. Thanks again!
We have them.....
Just ask. WTB section.
Discussion Starter #6
Can anyone tell me if I tested the relay correctly? I tested continuity between pin 1 and 2; 1 and 3. There were zero ohms. I tested continuity between pin 4 and 5; 4 and 6. There were 5 ohms. Does that sound right? I assumed it was bad so I bought a used one on eBay and it tested exactly the same. The driver headlight still doesn’t go down. I’m wondering whether I have two bad or two good relays??
1 - 7 of 7 Posts
