I know the 440cc are impossible to control with jus the piggy back so is there any other injectors out there higher than the 295cc that i could work with when the 295cc maxes out?
i think 4agze used some 365cc injectors... they will probably be hard to find. maybe you could hike up the pressure a bit more if you're using an adjustbale regulator until you hit some sort of balance between the piggy back doing enough for a good ride and enough fuel at high boost? or check club4ag.com for some if they ever go on sale?oldschool85 said:I know the 440cc are impossible to control with jus the piggy back so is there any other injectors out there higher than the 295cc that i could work with when the 295cc maxes out?
