Here ya go...Ill just type the rest out.
Curb weight - 3045 lbs
Weight dist. w/driver - 54/46
Wheelbase - 102.9 in.
Track F/R - 57.9/56.7 in.
Length - 183.5 in.
Width - 67.7 in.
Height - 52.0 in.
Ground Clearance - 6.3 in.
Overhang F/R - 37.9/42.7 in.
Trunk Space - 12.4 Cu. ft.
Engine Type - DOHC Inline 6
Bore x Stroke - 3.27 x 3.35 in.
Displacement - 168 cu in.
Fuel Injecton - Bosch L-jetronic
Fuel Reqirement - Unleaded 91 Octane
Exhaust emission control equipment - 3 way catylist, Air Injection, EGR, O2 sensor.
Layout - Front engine/Rear drive
Body/frame - Unit Steel
Brake System F/R - 10.1 in./10.4 in.
Swept area - 367 sq. in.
Steering type - Rack & pinion, power assisted
Overall Ratio - 18.1:1
Turns lock to lock - 3.1
Turning circle - 35.4 ft
Front Suspension - MacPherson struts, lower lateral arms, compliance struts, coil springs, anti roll bar
Rear Suspension - Semi trailing arms, coil stprins, tube shocks, anti roll bar
Now..I dont have the HP/TQ specs, but Im sure someone else can help you out there.
