83 Turbo '84 Dk Blue Auto-> 5 Spd... '85 ..gradually acquiring parts to Turbo ... have 82 Engine
Hi Rick ... the only reason I was considering parting out the '85... was that I didn't have room on my property for 3 Supras Jetta Winterbeater... & an enclosed Trailer... Managed to get a place to Store the '85... so back to the original plan of Turbo-ing it... So other than actual Engine parts I have excess of... I'm not selling anything else off ot it.Dave,
hello, I think we've sold each other stuff over the years.. Any rate, I need a small A/C hardline that is inside the evaporator. It needs to be from an 83 - 85 (or 86) MKII. I understand you are not wanting to spend time taking parts off, but this small line is all I need, not the entire evap. I have a Wanted post made for it in the Wanted Section, so please read that if you think you might have it and would be willing to take the case apart (easy) and unbolt the line. Its attached to the expansion valve... probably take 5 minutes to remove from the evap.
thanks for your time,
Rick
A/C Liquid Line tube on Evaporator Needed
Hello, Although no longer available the OEM part number is 88716-14820. Its also found on the 83-85 Celica. It's the Liquid Line tube, and I've indicated it on the photo and diagram below from the TSRM. It attaches inside the evap onto the expansion valve and the Pressure switch also connects...www.celicasupra.com
I might already have the part Ur after ...from another car... but it could be ANYWHERE... inside a 53 ft Trailer...
I'll keep an eye out for it ... as I'm organizing other stuff... but can't spend the time ... just looking for 1 single small part...
Cheers,
