1 - 3 of 3 Posts
Hey guys,
My passenger door power lock on my '83 Blupra will not unlock when I use the center console lock/unlock button, but it will lock when I use the same button. If I were to unlock the car from outside using the key on the passenger door then the driver side door does unlock. Somehow it seems the unlock signal is not getting to the passenger side door from the center console, while the lock signal is. I was thinking of taking off the door panels to check to see if there are any loose wires and was wondering if anyone knew which wires I should be checking. Also, it could be the relay and was wondering where that might be located. Any thoughts?
- Mike
1 - 3 of 3 Posts
