Make sure the AFM isn't stuck open, check the resistance on the ECU temp sensor, check the cold start injector time switch. Also check the cold start injector itself. (you can pinch the hose shut with vice grips or pliers).
Good luck!
Jamie
Good luck!
Jamie
