1 - 3 of 3 Posts
ok i know pictures help but my camera took a dive a couple days ago. the following is on an '85 p-type
Anyway, there is a small yellow round plug that is coming out of the main harness between the upper intake and the distributor. on the inside of the plug is a little square female end.
i can't figure it out. if no-one has any idea what im talking about without seeing it, totally understood i will try to get some pix asap.
just for some reason my car is frying alternators and i can't figure it out. :32:
thanx for the help if given.
Knock sensor?
If its a round connector with a square terminal on an '85 then it's a Knock Sensor for sure.
I just replaced my knock sensor two days ago
Look under the intake mani on the side of the block.
Is it the original engine?
1 - 3 of 3 Posts
