1 - 3 of 3 Posts
Just learning that side mirrors have a tendency to break [internally] and are almost impossible to find. Any ideas on fixing? Also have spotted an 86 that mirrors are intact and functioning. Realize the outside has changed but am wondering if the bolt pattern is the same and would they work?
Any help greatly appreciated.
Thx
Steve
Is this for a Celica or a Supra? All the 82-86 (or 85 Celica) mirrors can be bolted on. Note that the 85-86 Supra mirrors have heaters in them with different 5 wire connectors so you'd have to switch the connector to use them. If you remove the mirror and the guts you can see the internals. Usually the plastic boss that supports the spring tensioner shears off. I'm sure with copious amounts of glue and backyard engineering you can figure out something decent.
1 - 3 of 3 Posts
