HELP!!!!
Ok, I have gotten around to my Supra that I have been meaning to install the original stereo back into the car. As always someone cut the freaking wires. So I bought the wiring plugs on ebay that plugs directly into the stock stereo. Luckily, whoever installed the stereo, labeled what goes where. However, there are some leftover wires. I took photos of the remaining wires. The wiring diagram on the TRSM to me may as well been written in Greek. No help there. Here is what I have so far:
Speaker wires are no problem, I have those hooked up. Antenna wire coming from the radio plug (solid blue), they had it go to a Pink wire w/blue stripe and red tags combined with a Black wire w/red stripe. I have a remaining Pink wire w/blue stripe and red tags. I suspect this may go to the other antenna wire coming from the plug, the Blue with white stripe. I have two Brown wires w/blue tags and one Green wire with red tags remaining. I also have the Orange dimmer wire coming from the radio plug with no home. See photo.
Next problem, one that I have been meaning to get to. Finally have a photo of it. The solar item on the dash on the passenger side. I took out the glove box insert to take a photo of what I'm talking about. There is nothing to plug it into. Below it is another plug and it definitely doesn't fit. They are two male plugs. This plug is a single wire Black w/red stripe. I figure maybe it plugs into what goes into the mystery hole, but whatever is supposed to be there is missing. So I have two plugs and nothing is around that looks like it plugs into.
HELP!!!!
HELP!!!!
