Well I really did it this time! I just ported and rebuilt my head and rebuilt the top end. Got it all back together and took it out for a spin. Ran Great! Got home and had oil in the valley. I didn't realize (at the time) that the cam tower gasket were different for intake and exhaust side cam towers. Tore it all down, swapped the gaskets, put it all back together and now I am running rough at idle, I suspect that I skipped a tooth on the timing belt. I noticed that I have a lot of slack in between the intake cam gear and the oil pump gear is this normal? Could my tensioner be bad? I played around with the distributor and it runs best at full advance on one tooth and full retard on another. I think I should start from scratch with lining up the cams and crank.
Heres what I think I should do, any input would be great. Start at TDC and make sure that i line up with the zero on the timing cover with the notch in the crank pulley. Then line up both cam gears with match marks on middle match pin (they were both on the middle match pin when I removed them). Then replace distributor to point to number one. Is this right? Thanks for any comments.
Jason B (why didn't I just put the gaskets in right the first time!)
