Well I am bored at work so I thought I would post an update on my project.
The block is in the car (with the head on). I recieved the IC and piping from RC on tuesday but there were no silicone connectors so I am waiting for Aaron to check his email.
I have the 295cc injectors in the manifold with all new seals and the clips have been wired into the harness and harness is back in the car.
The machine shop braized the oil return fitting in the wrong spot (not sure if it was my mistake or theirs) so now I need a longer oil return hose (Aaron, check your email).
Other stuff I still need are the upper turbo oil flange, small brass fitting for turbo oil feed line, Fuel pressure gauge (still trying to figure out where to put it), flexable exhaust pipe to connect the turbow elbow to exhaust untill I can take it to the muffler shop, some misc gaskets, spark plugs and possibly an oil filter relocation kit.
I have the boost gauge and A/F meter in the pillar pod. The pillar pod was ordered from Horsepowerfreaks.com. I need to take a heat gun and mold it a little but it should work fine.
I have been sick the last 5 days so I havent been able to do a whole lot. Hopefully I will feel better by the weekend and I can get most of the engine back together. Provided I get the parts I need from Aaron I hope to have it done or at least running by june 1.
