1 - 4 of 4 Posts
Head is going to machineshop for rebuild. Going to re-gasket the top end, probably with felpro since the are cheap and available. Thinking of installing my new turbo, 440cc inectors, and trying to rundown some EDIS stuff so I can have an easier time doing my MSnS. Timing off of the dizzy seems like its a PITA. Any suggestions while I have everything torn down? Also do the 'stopper' type metal head gaskets hold up better than the standard ones?
Well if my attempt at timing off of the dizzy works (12-1 wheel) for my MSnS, I still have a full EDIS setup with the trigger wheel, pickup, controller, some wiring, 6-pack coil, and newer coil wires that I will not have a need for.
For the head work, just do the standard stuff. I would also inspect the piston bores and make sure that the block mating surface for the head in in perfect shape and is level.
1 - 4 of 4 Posts
