Hi,
I hope I am not posting a duplicate, but I did the searching and could not find exactly what I am looking for.
My A/C did not work on my 82 L-Type. I knew it had a leak, and was emply of refrigerant and that it was still R12, but that was about all I knew. So I thought I convert it to R134a and use a leak-sealing refrigerant. Realize I know nothing about A/C systems..... or really even cars for that matter.
So, I bought the conversion package for ~$30. The instructions seemed so simple: "Find high-side service port, put adapter A.... Find low-side service port, put adapter B..... fill 134a refrigerant via low-side service port. Adapter A will not fit low-side and adapter B will not fit high-side." This is paraphrased, but you get the idea..... easy.
Well, I did not find two ports, I found four.... two on the compressor, one near the dryer and one just kind of running on the line leading to the cabin. All of these are identical fittings... so adapter B fits all of them and adapter A fits none of them. So much for easy. :? I don't know which is high, which is low, etc. Maybe all are low since same fitting, but I doubt it.
The instructions also seem to indicate that the port running between the compressor and the dryer was high side. Well, I had two of those. While given an adapter for the high side, there were no instructions to actually do anything about it.... so I figured I'd leave it off since it wound not fit anyway. I, therefore, assumed the other one on the compressor, running away from dryer, was low side.
My life insurance is up-to-date, so what the hell. I put the adapter (the only one that fit anything) on what I believe to be the low-side off the compressor and I filled it with 2.5 cans of 134a Refrigerant... and got Cool Air!!!!!
I just did this last night, so I did not know if it will all leak out. Regardless, I'd like to see if anyone else has had similar experiences and maybe some feedback on what I did. If I did some stupid things here, I'd appreciate being told so.... so maybe I won't do them in the future.
Sorry for the long post.... I hope someone reads it. Thanks for any input/advice.
Doug
1982 L-Type
Doug
1982 L-Type
