1 - 7 of 7 Posts
hi, im looking to see if the mk2 rear body to hatch seal is still available? im looking for whichever does not have the metal fingers in it(mk2 or mk3) to replace my original that has those metal fingers due to the metal causing rusting issues. which would be the better seal to get, fit opposed to price.
thanks
Discussion Starter · #2 ·
i think i found that the mk2 seal is no longer available. so does the mk3 seal have the metal in it?
Metal fingers? All the MK2 and MK3 ones I have seen, are just a rubber seal.
what i mean is that in the rubber where the seal pushes onto the body there is metal tabs that help to keep the seal on the body. you can not actual see the metal unless the seal is maybe damaged but the metal is there.
Yea...the MkII trunk seal is no longer available. And the rust issues are usually from the body seams outside the seal leaking, causing the pinch seam under the weatherstrip to rust, not the seal itself.
1 - 7 of 7 Posts
