1 - 2 of 2 Posts
Mark,
Are the rear Backing plates that protect the rotors available?
If so, how much? Both left & Right.
Are the bolt that hold the rear calipers available? The ones that attach the calipes to the arm.
Are the cushions for the spring available? both upper and lower.
Are the bolts and bracket that hold the rear bumper cover on still available?
Adding the following brake parts:
Shoe Strut and Spring for L&R
Return spring for L&R
Holddown Spring for L&R
Shoe adjusting screw set for L&R
Pins for L&R
Spring for L&R
Bolts holding the backing plate to the control arm for L&R
Please let me know.
The car is an 84 P-type
Carlos
Sorry for the delay Carlos,
These parts are all still available unless noted below (Est#18515)
L & R Backing Plates - $149.81 each
Caliper Bolts - $.68 each
Spring Insulators - $37.17 ea. TOP, $16.66 ea. BOTTOM
Rear Bumper Brackets - DISCONTINUED
Rear Bumper Nuts/Bolts - $.73 ea/$.62 ea
Shoe Strut and Spring for L&R - $7.70 ea
Return spring for L&R - $3.77 ea
Hold down Springs for L&R - $1.33 ea
Shoe adjusting screw set for L&R - $41.45 ea
Pins for L&R - $4.24 (x2) and $1.42 (x2)
Spring for L&R - $5.30 ea
Bolts holding the backing plate to the control arm for L&R - $.68 ea
1 - 2 of 2 Posts
