I picked up a set of basically brand new stock springs( I think) from the local U-pull. Only 17.00Can
They had some colored stripes on them-black springs with an orange stripe and two yellow stripes on each spring. Do these sound right? When I removed them at the wreckers I disconnected the lower shock bolt and the sway bar link(?) then lowered the control arm. The springs came right out but so did the axle from the diff. The TSRM says I have to unbolt the axle shafts from the diff. But I remember a post about installing the springs without removing the axles. Am I misremembering? And If I have to disconnect the axles then how hard is it to realign them? I have never removed them and am unsure about the connection. Any help would be appreciated.
Thanks
Thanks
