I just replaced the end links and bushings on my front sway bar / anti roll bar / stabilizer bar, as well as the frame mount bushings. (Maybe I should create a poll on what different people call it. TSRM says stabilizer bar, so that's what I'll go with.) Oddly enough, the frame mount bushings looked really good. I'm guessing they got totally roached out some time in the past and the owner was forced to replace them when the stabilizer bar started knocking around. The end links looked like they came factory, see pic below. Still good to use, right? 😆
Does anyone know if there's a source for the rear stabilizer bar bushings in OE rubber? If rubber is not available then what's a good recommendation on an aftermarket set?
