1 - 6 of 6 Posts
Thought I would share.
The actuator is a GS300 fuel door release. Red parts are 3D printed. There is the bracket for the actuator and an adapter for the latch release where the outside key contacts. My hatch is shaved so you don't see the key latch release.
Still need to finish the wiring.
Had to drill 2 holes to mount the bracket
14384
Discussion Starter #3
Completed the install.
Needed a relay due to the brain box not having enough current capacity.
Noticed my latch was kinda gummed up which caused the latch not to release when the hatch was fully closed. Cleaned it up with some WD40 lubricating spray and works as it should.
Discussion Starter #5
It is for a keyless system I installed. I don't have a switch per-say. If you are in the drivers seat you still use the stock tab. I don't have a rear wiper so I used one of the wires for it that runs from the drivers kick panel to the back. Could put a switch at the stock location since the wire runs very near there. It is negative trigger due to he brain box.
I need to do this for the fuel door which is a pain in the but to open.
1 - 6 of 6 Posts
