Repairing battery acid damage (Lower radiator support and frame rail)
217 Views 4 Replies 2 Participants Last post by  Nerdmobster
10
Kind of followed this post - Lower core / radiator support replacement Write Up
I found that a band file worked a lot better then the drill bit OP used for the spot welds.
Pulled the whole front end off a boneyard mk2.
Plant Motor vehicle Grass Gas Pollution
Car Vehicle Automotive lighting Hood Automotive tire
Sky Plant Wood Tree Automotive tire
Plant Tire Cloud Sky Automotive tire
Then taking out bad part.
Bedrock Wall Geological phenomenon Recreation Paint
Motor vehicle Wood Automotive exterior Gas Automotive tire
Vehicle Hood Motor vehicle Automotive tire Automotive design
Automotive lighting Hood Motor vehicle Automotive parking light Bumper
Photograph Motor vehicle Automotive tire Wood Automotive exterior
Tire Automotive lighting Automotive tire Wheel Hood
Reactions: 2
1 - 5 of 5 Posts
6
After removing all the spot welds, the frame rail is cut
Automotive tire Motor vehicle Wood Gas Automotive exterior
Automotive tire Motor vehicle Automotive design Automotive exterior Bumper
Automotive tire Motor vehicle Tire Automotive design Automotive exterior
After doing the same to the donor piece compare the two.
Plant Grass Wood Groundcover Gas
Cutting frame flush then test fit new piece
Bumper Automotive exterior Hood Gas Automotive lighting
Hood Automotive tire Motor vehicle Automotive design Bumper
Tacking it in
Automotive tire Tread Motor vehicle Wood Gas
Hood Motor vehicle Automotive tire Automotive design Automotive lighting
Hood Motor vehicle Automotive tire Automotive design Vehicle
Automotive tire Motor vehicle Bumper Automotive exterior Gas
Adding more welds
Automotive tire Motor vehicle Automotive fuel system Gas Auto part
Hood Motor vehicle Automotive lighting Bumper Automotive exterior
Automotive tire Motor vehicle Wood Bumper Automotive exterior
Motor vehicle Wood Bicycle part Auto part Machine
Next up is grinding down welds and adding plates. Will update soon...
Reactions: 1
NMaster, Props to you for saving your MK2!! Look at Por-15 rust treatment/converter.
Reactions: 1
Thanks! I will check that out.
Reactions: 1
1 - 5 of 5 Posts
