1 - 4 of 4 Posts
Unfortunately the last owner of my Supra mangled the modulator in a half-assed delete and I can't find a stock modulator replacement to save my life. Does anyone know of a place that has either a good match or a used OEM part for sale? I've hit all the standard sites and no luck.
Mine's a 1985 Supra, parts site says I need either of these if it helps:
Toyota 2587043030
Toyota 2569043021
Any input would be super appreciated
I would suggest going to a junkyard and looking around similar vintage Toyotas. They basically all look about the same and function the same, but they have vacuum ports pointed in different directions typically. Places I would suggest looking are 7MGEs. Cressidas from 85-87 use the same part as an 85 Supra.
Edit:
You may want to look at 22RE since they are still available new from Toyota for about $70 dollars. P/N 25870-35040
1 - 4 of 4 Posts
