21 - 29 of 29 Posts
I used the Denso 950147 pump as well. The gas tank drain takes a 3/8 " ratchet. The gasoline will come out like a fire hose! Loosen the gas cap B-4 starting out to relieve the tank pressure. It's also a good idea to crank the engine over to relieve any pressure build up in the system B-4 cracking the gas filter banjo bolts.
Do not use any normal fuel hose to connect it inside the tank. It's special and the clamps are, too.
Denso.
I had to do a small mod to the hanger insulator.
Mod.
If you leave the sending unit assemble out of the tank, it makes it easier to get the pump back into the correct position around the baffles. Pay attention during removal! Rotate, twist and tilt, not in that order.
Baffles are in the way!
Reactions: AJ
Discussion Starter · #23 ·
Dang Dave! That's clean tank!
Thx for the info and pic. Were there links in the post? If so, they are wonky...
Discussion Starter · #28 ·
Found this one while I was browsing your list. Good pics and tips on how the fittings turn.
Discussion Starter · #29 ·
Searching on here is like searching for YouTube videos. You can find some really cool stuff. And you can go down a rabbit hole for HOURS!!
21 - 29 of 29 Posts
