Pics of the new distributor, cap and rotor. I followed the TSRM to the letter, but the rotor faces at 6 o'clock. Verified 0 degrees on the crank (TDC of compression). Verified cams align with marks. When putting new distributor in aligned mark on the housing with the pin on the gear shaft. Thought the rotor would have been on cyl 1. We shall see I guess.
Old (on cyl 1)
New one installed.
Masked up and wire wheeled the rest of the interior floor/sides/ POR15 coating done for the floor and some of the side of the interior. Got a few patches to do for for the rear wheel wells (half dollar size hole). Was thinking about doing fiber glass for the spare tire well.
While trying to crank the car for spark I got board and fiddled with the hvac controller... scared the hell out of me when the blower kicked on at spit dust and debris
I got the blower motor assy out, cleaned it really good. I am still unsure how to get the box out/apart for inspection. I would like to verify that there are no more critter condo's as that would be the last place anything could be. I have seen pics/vids on people taking apart the box and they are nested at the evap.
Also got all new clamps on the intake. Others were done, a few had to be cut off. I was thinking of painting the intake flat black... I think those kind of cosmetics are a down the road item on the spread sheet lol
A lot of work today, both on the car and prepping my shed for a space for a new 30 gal compressor. Still no spark. I so far verified:
Grounds cleaned and attached
- Battery to fender
- Battery to block (under intake manifold, near fuel filter)
- Intake manifold (underneath the runners)
- Cam cover to firewall (intake cam cover to firewall, short 6 inch wire)
I know there is one more cable near the bell housing of the trans that I can see chewed, I will have to address that obviously. I cant see that being the culprit... theres so many grounds that are verified good! As always... we shall see.
I verified at work that the primary and secondary circuits of the coil are within spec.
I did swap an ecm (84 cressida) I got when buying the rear seats. No effect.
I still should probably check continuity from ECM to ignitor. Grabbed some back probes from my box last night.
I measured voltage (or lack there of) when key on engine off at the black connector going to the coil, and the three other green connectors going to the ignitor... I had what seems like a 5v ref signal but the rest measured nothing (.4 or less).
Made a spreadsheet for all of the tasks that need to get done. I am usually extremely organized, but this project has occasionally made me drink a few more Corona's than normal lol
I always found staying organized keeps me on track... and watching tasks go to "green" is a great way to visualize the win
Obviously everything is subject to change... but I think it will slow down a bit and I can start truly goal setting tasks. When I first got the car, every time I did something, it lead to something else (flip up rear seat, now needs seats and dye...pull out interior, needs rust repair...etc.).
It is going to be awesome when all thats left is exterior cosmetics...
