21 - 40 of 168 Posts
Discussion Starter #21
Hmm let me think about that and consult my EWDs. What year is your car again?
1983 supra with a 1989 7mgte
Exactly what im talking about!! thats the sucker, your diagrams look different than that plug.
Discussion Starter #25
Yupp because I haven't ever seen a plug like that, must be an 83' thing. I'll do a chart up for it. to sub in for 83's.
Dang it! Ok. Well thank you for all of your much appreciated help and patience. I'll be here waiting patiently hahah. Thank you
Jeremy
Yep, it's the 83's version of the 84/5 E1. Color codes are the same, just like the 7mgte side of things, just a plug change.
Delve into the 82 EWD ;) just for giggle .... both plugs are different again, and, you have to add a wire, and swap gauge clusters, to have a check engine light, and, the starter wire runs thru the engine harness like a MKIII.
Discussion Starter #28
OH JOY! :) why do we do this to ourselves? haha Yeah I've thought about the 82' pre-TCCS but haven't felt the need to try it yet and make a test piece for my 82'. It's just to purdy to screw around with it. :p
Lmao ... Why do we do this to ourselves ? Can't speak for anyone else, but, it -- was -- fun, exciting, challenging at one point.
Then, it became another job, monotonus, boring .... working at the wrecking yard, building cars, and trying to start my own business -- twice -- flat freaking burned me out. Add in the tight asses here, and the issues, that only twice, were my fault, and not getting paid for the addition 100's of hours of problem solving overall .... and I threw in the towel. Many things unrelated to the cars/forums, helped with that decision, but, leaving the industry as a whole, and making it " just " a hobby, relieved enough of the burden and stress, to keep me around.
Discussion Starter #31
They both go to the same on B1 or you can do just one. doesn't matter.
i got my car running with your pnp instrutions but it does not seam like it is running on all cylinders and what 7m relays, moduals in the engine bay that the engine wiring harnes plugs into do i use if any?
Hey Lee. Just checking in to see if you could still help me with the configuration of that pita 83 year plug? Thanks in advance.
Jeremy
Discussion Starter #34
Well good to know you got it kinda running. I used the 7M ignition module and injector resistor box. The rest is just the 5M body harness stuff. Might want to check your timing/Coils/CPS.
Jeremy
Yeah I'm still planning on doing one up for you. I've just been consumed with my swap, SupraStu's swap, and a bunch of other little random projects. I'll do what I can by the end of this month
Cool deal Lee! Thank you. I was just hoping you didnt forget about hahahaha.
Jeremy
Jeremy
Match the wire colors from the Lee's diagrahm to your plug. Yes, it's as simple as that to get it to work for the 83.
Dude on tps what voltage you sub post to see on the plug from the top to the bottom, i am having problem with it i went for a test drive it was good for 15min then it start bucking when you go near the throttle but dose mot stall. i got a code 41 tps and a code 31 maf, i ordered another tps but i don't want to burn this one to.
Discussion Starter #39
yeah I usually look up those on all data or the TSRM online I don't have a link to the TSRM but you can find it on here.
Let me pick my brains up off the floor and try this!
