i am going to be replacing the rod bearings on my 5mge and i wanted to knwo if their is anything else that i should get to replace while i'm at it and have the engine apart and all that kinda stuff reason i'm changing the rod bearings is because their was a knocking noise and it's gotta be the rod bearings so i've decided to change them and was wondering if theirs a list of other things that i should have cheaked out and/or changed after i put the rod bearings in before i start the engine up again most likely going to change all the gaskets and everything like that and wat else should i change or take a look at before i put the engine back to gether and start it up??? the noise appeared after engine ran very very low on oil more oil was put in but went to more of a thumping noise wandering what should be replaced beside rod bearings?????
Dan
Dan
