1 - 4 of 4 Posts
car started out not wanting to go into random gears. no it will consitantly not go into 1st 3rd or 5th. even when the car is off it will still do this. it is a hydrolic clutch. any suggestions?
I t may just be the plastic cup under the shifter housing. Remove the shifter boot and pull the 4 bolts on the top of the tranny. Pull it out and have a look.
If that is ok look for peaces of debri that may be in the way of the shifter arm. You may need to pull the 6 bolts for the bigger cover. You also need to lower the crossmember to remove the other cover.
you were right. theres a plastic bushing on on the ball joint at the base of the shifter and it was shreded in half. thanks for the help, i was about ready to drop the tranny to look at linkage and syncros. :duh:
Billy m shifter bushing.I suggest you invest 39 bucks
1 - 4 of 4 Posts
