first and formaost of my ideas is true duel exhasut,me and my friend talked about it today.
pace setter header jas 2 2" pipes (1 for e cylinders 1 for other 3) mate that to 2 2" pipes with a small 1.5 " crossover for equal pressure and o2 sensor
ideas on how to run the pipes differed, one way was weld the pipes together and go back on the same side to 2 mufflers on on side (might be a squueze), next was to remove fuel tank and get a fuel cell (cool anyways) and notch the passenger side frame like the drivers side and go out the back, nextwas go with fuelcell but run both pipes together tillafter axles then go out both sides.
next idea, with a fuelcell get a performance fuel pump.
next, get lowering springs and the get rubber spacers that are designed to increase spring height so you don't grind on everything. get them from partsource or other part stores.
make a hyperground system from welding cable and electrical connectors, i chose gold plated ones for important ones like block to battery and then just get decent ones for everything else, you can make realpower from this cheapwork, use amppower wires if you want todress up engine bay at the same time.
aquatune,which i have mentioned in previous articlesis alsopretty neat and tornado systems and other similar ones,same idea was behind the chevy vortec engines i believe. and they made more power.
