I am sure you did it, but did you make sure you kept enough brake fluid in the reservior when you were bleeding the brakes?
You bleed them by starting from the farthest from the brake master, to the closest. so, rear passenger, rear driver, front passenger, front driver.Did you bleed them before you pumped them back up? That's what I meant by too soon and I have heard someone say to bleed in an X pattern. May have to do it twice.
No mk2 has abs. It was misinformation on his part.you never push fluid back from the calipers when you have abs,,, you should open the bleeder and push old fluid out of the bleeder cause you can get crap in your abs!!!!!!!
lol that is correct.This is other car section dennis lol. tC is scion tC. NOt terra cota![]()
it has abs not hiss supra and to who did the brake job you may have messed up your abs!!!No mk2 has abs. It was misinformation on his part.
