question, i did my brakes the other night on my tc and, all i did was, push the piston back on the caliper, put new pads, and closed the caliper and done! well when i got in the car, i started it, and the pedal went straight to the floor. so i figured, i'll just bleed them and problem solved. well, long story short, i bled all four calipers, starting with the one farthest from the reservoir and NOW it sounds like when i hit the brake, air is being pumped through the lines, or there is a leak. here is the interesting thing, it sounds like it's coming from the ABS...
now, the car stops fine and everything, but when you push the brake, it doesn't get harder as you push it, it's like one slow descent to the floor. i'm going to take it to Toyota today, multiple people said it sounds like it has a vacuum leak, just thought i'd ask you wonderful intelligent people first. thanks for your input ahead of time.
