1 - 8 of 8 Posts
Boost-a-holic
Hey all -
I'm looking for a subwoofer enclosure (for the Blupra) that will fit in/over the inverted spare tire of a MkII...I'd like to put in a 10" sub there with the amp under the wood panel next to it. I've seen pictures of them, just wondering if anyone knows where I can find one/get one made...thanx.
Boost-a-holic
Appreciate the help...problem is, that one's too big. I'd like to keep the spare - looking for an enclosure that'll actually fit in the back side of the spare-tire's rim (spare tire would be flipped over, so it's back-side up). To use theirs I'd have to lose the spare. Thanks.
-- Bob --
I would look for a used factory Acura RSX sub I'm pretty sure those fit inside the spare. Will the MkII spare even fit in the tub upside down? That center attachment horn sticks up a ways from what I remember. Also I don't think you could get the volume you need for even a sealed port box inside the factory spare. I think if you want hidden you outta just use a free air sub in the trunk wood.
I'll need to keep looking around when I have time, but...
About 10 - 12 years ago, I remember that Pioneer used to have a subwoofer enclosure (that had it's own built in amp) that sat inside the inner portion of the spare tire iteself. Looked pretty nice, until I demo'd it in a store... Lot of the sub-bass frequency's just royally sucked & sounded horrible, but the mid-bass sounded fine. I just went to the PioneerElectronics website & they no longer offer anything resembling this
I don't know if any other company's offer anything close to what you're requesting.
Last ditch option would be to go the Don Culbertson/Agatha route... Problem is that he used a custom made molded fiberglass enclosure on his, using I "believe" a small donut spare (I don't believe he has the full size P-Type wheel in the trunk anymore)... And to fit it in, the wooden trunk bottom was raised up an inch.... Am guessing that you're not looking to do that..
I'll help out your memory a bit Chris :wink:
Don C. has a small spare,IIRC they come in the Celicas.The sub enclosure is homemade using the original wood decking,and then a second decking added on top for more clearance and I believe strength..
Any progress on this Bob
Hi Bob,
Have you made an progress on getting the subwoofer installed in the spare tire?
Jeff
Boost-a-holic
No, not yet....looks like I'll wind up going with a custom enclosure like I did with the Redpra. I don't think there's enough depth if I keep the full-size spare - though I 'd consider using one of the small spares if I could find one that will work if needed and that will give me enough room for an adequate-sized enclosure.
Since the swap, I've found a few more rattles in the back end (cargo compartment) than I used to have...but then again, the faster you go, the more likely you are to find them :) I'm going to to go through and tighten everything up back there after the holidays.
1 - 8 of 8 Posts
