You dont need 330s. Many are using 210cc injectors available in MR2s and GTS corollas they are blue top. I have heard that these are good for 8-10 psi of boost.Avp23 said:im trying to do the 5mgte conversion and from what i hear, that the 5mge's have 182cc injectors. and when you put a turbo on it you need to put 330cc in? thats only what ive heard
thshiiam said:what is the stock boost you can run on the stock fuel system?
Is that on a stock engine? or a rebuild?85TurboMKII said:about 8psi is the max with a rrfpr. I tried 9 and it went nasty lean. go with the 295's you'll have pleanty of fuel. I'm running at 10 right now and my SAFC is actually in the negative all the way across after tuning.
