41 - 60 of 63 Posts
Thanx for posting this thread. ive put in about 8 hours searching these threads looking for advice on my 84 swap. i want to put a twin turbo in it. clearly, after reading your post i do not have the cash flow for it. i have all the tools in the world and a shop. not the funds right now though
one thing i'm having trouble finding is the ideal turbo(s) to use with the 2jz. is a ct-26 an option?
im gonna do a single setup and im just looking for 4 or 500 hp, is a ct-26 even possible?
why would you build a custom manifold to use a ct26 when there are SOOOOOOOOO many turbos out there that spool just as fast and make ALOT more power? look on supraforums at the dyno section. lots of turbos will do what you want, but id look at a borg warner s300 series turbo. full race has alot of the different ones on their site. hell, the gt45 ebay turbo will make the power your looking for and is ~$250 shipped. less if you find the right seller with a sale going.
http://www.full-race.com/store/turbos/
damn i jumped the gun on getting a ct26 in a trade thinking i could use it. i guess ill have one FS in the near future. thanks for pointing me in the right direction. i'm new to building turbo motors
why would there be a suggestion to run dual fuel pumps for anything over stock boost? thats ridiculous.
the bosch 044 and even the shitty walboro 255 are more than capable of over 400whp. dual pumps dont even get considered until going above 600
Whistles
Older thread with older tech that was good for the times. The newer 320lph in tank pumps flow 1000hp worth of fuel*
Whistles
Depends on the design. The RPS style manifold design like the SPF1 likes to creep at high RPM.
Especially at higher boost.
I'm running two 44s, myself.
Whistles
FYI this thread is from 2010, a bit has changed since then. There are off the shelf mounts now, and a bit more resources on the board. Lots of people have done this swap now. That sad, any turbo motor swap in a mk2 is a big deal.
Totally agree. Even a 7mgte swap is not for the faint of heart. While the motor does drop in with no modification, other than sourcing a front sump oil pan, the wiring, intercooler piping, tranny considerations and other misc items is work. Best advice I have is research every aspect of the swap. Do your homework. Almost every swap, mod, fix has been documented on this forum for the mk2. I usually do a Google search and append "site:celicasupra.com" at the end of my key word search. That way you're searching specifically on this forum.
41 - 60 of 63 Posts
