I got done rebuilding and porting my head a few weeks ago. Adjusted the timing by ear at that point as I did not have a light. Got a light yesterday. The car was running fantastic, but I figured I'd check the timing anyhow. It was at like 30 BTDC (or at least that is what it looked like). Here is the deal I figure something is out of whack here. I can get the timing to about 12-13 BTDC with the dist maxed out in the clockwise direction. With it set here the car does not seem to run as strong or be a responsive as it did with the timing at 30 or so BTDC. Meanwhile under my hood it says 10 BTDC is the factory spec which I can't quite get. I don't think the distributor is off a tooth or I would not be able to get it to run well at all. Did I maybe screw up lining up the crank and cams? I thought I double checked everything pretty well. Maybe I had an extra tooth of belt in between the intake cam and the crank pulley? Should I put it back the where it runs great and be happy or rip it apart again and see if I can get it to run that way at 10 BTDC? Any ideas? I know if it was running so well why did I mess with it!! Thanks for any input.
Jason B who just can't leave well enough alone.
