1 - 5 of 5 Posts
Okay, so i replaced my whole sunroof assembly, from the metal, to the track, now the motor isn't coming into contact with the tracks teeth, it just spins, is there a difference in years for motor assembly? Like my motor's teeth do not reach the teeth, needs to be longer?
What year? I just removed a track and motor from an 84. Works fine.
nope all motors are the same
pull out the track and check for binding
Just tried to mess with it again, still not working.... i took out motor watched it spin, and i know the track moves because i moved it by hand.. I don't know it's not even touching the damn track, it's just spinning when i bolt it up.. :duh:
I would pull the track out again. Check out the cables and track, but especially make sure the cog and motor mesh to pull the cables. I think the cables have some ridges or teeth that a cog meshes with. If those aren't stripped, the problem might be how you are installing it. Just try it again, and make sure the cog/motor mesh. You can manually turn the screw with a flathead screwdriver to watch it work.
Also, check out Marblehead's thread on making the final adjustment so that the roof closes completely: has to do with using a screwdriver to manually turn the adjustment screw at the motor cog the last half inch or so. I couldn't find the thread...
1 - 5 of 5 Posts
