1 - 4 of 4 Posts
G
Oh, I forgot to ask. Does anyone know what size poly bushing from pst works with the fron and rear sway bars? the person at pst stated that there are none but I believe if I had the proper size I could order then generically.
All Input is appreciated;]
Respectfully
Bri
I don't know the size for it, but I think you'd probably be okay with Energy Suspension's poly set for the Supra. Hell, you can buy 'em with all the hardware in several lengths nowadays at Kragen! I saw it the last time I was there.
The poly set I got with the Addco bars were the same size as the set for my '87 Xtra Cab, so I don't think you'll find a lot of difference in them from vehicle to vehicle-although I could be wrong!
Good luck!
Brian,
If you are still on the stock OE swaybar, then the PST bushing size that you need to get is 25mm. Can't remember what the diameter is in millimeters for the Addco bar.
PST does NOT make bushings for the rear sway bar, they only make rear control arm bushings. You'll need to think of something else for the rear bar, (get the Energy Suspension for the rear, or if you still have the OE rear 15mm bar, then "try" and get some replacement ones from Toyota (I believe these are now either Class D or Class E items, so good luck).
If you're talking about endlinks then you can go to Auto Zone and pick up some endlinks....those are pretty generic; just match the bolt length. The chassis mount bushings would be different. When I ordered my PST bushing set I told the guy I had an 1-1/8" Addco in the front so I got Polygraphite swaybar bushings (After modifying the included brackets). You might be able to call PST or Energy Suspension and order stock sized poly bushings.
Good luck
Nick
1 - 4 of 4 Posts
