Hello every one,
I wanted to contribute something to the forum so here it is. Techno Toy Tuning weldon LCA kit built.http://www.technotoytuning.com/productdetail.php?p=772 I have not put these on yet but will do it after I get the car running so I can give an idea of before and after. Right now Have T3 camber plates, T3 strut rod, and super pro poly control arm bushing. Unfortunatly forgot to take pictures at first so do not have a picture of the control arm before I cut it. These are supposed to give between 1" and 1.5" of lenghting the control arm. Oh yeah kit was $203.44 shipped with CA tax. Kit is $175 also got two new control arms off ebay for 100 bucks shipped so $275 and a 12 pack of beer for my friend to use his shop.
First we took the whole heim joint peice with the block that welds onto the control arm to figure out how far back to cut it.
After we cut it we put the block in place to weld.
Here is some of the welds we welded all spots around the block the connect to the control arm
You could cut off the side wing tabs of the control arm for a cleaner looks but I figured no one would see these really once there on the car.
I also removed the stops for the steering knuckles im sure some one would say not to do it but I did for what im using these for. Drilled the spot welds then knocked it off
We then grinded the plates for the boxing of the LCA to make them fit inside of the control arm.
And to make them flush with the end we bent them down so the would connect to the block of the weld on kit
you could also cut the wings off the side of the control arm and get these grind these down further to make the touch the block but this is how I did it. Doesnt look as clean as the ones pre made for the AE86 by techno toy tuning but I'm sure it will work.
We then tacked them on then welded them up.
After that we threw them on a drill press and made a new hole for the sway bar to go through. the center of the hole is 1.25 over from the center of the other hole.
With all that done gave them a coat of paint and this is how they look now.
Wanna put a comment here I ended up drilling a hole through the bottom plate so i could get a socket in there for the sway bar end link.
