Toyota 2JZ-GTE based, built to sustain power levels of 1,000 BHP plus.
Price includes new base Toyota 2JZ-GTE engine, steel billet 90mm stroker crankshaft, 87mm forged pistons, forged I-beam conrods, metal head gasket, custom camshafts (specifications depend upon power and endurance level requirements), complete race valve train, race water pumps, torque plate modification, high rpm harmonic balancer. These motors also include the intake plenum - as due to the nature of the 2JZ engine design, sustained equal airflow is imperative at high power levels. These engines have an increased bore and stroke to bring their displacement up to ~3,210cc.
All boring, honing, balancing, porting, polishing, combustion chamber reshaping, camshaft tip processing, shim adjustments, valve lapping and seat grinding is performed.
NB: These packages do not include fuel system, ignition system, exhaust manifolds, turbo chargers, oil and water cooling systems or any other ancillaries.
Price in Australian dollars is Au$50,000. Current exchange rates into any denomination are available at:
http://www.xe.com/ucc/
