1 - 20 of 21 Posts
Not sure if anyone was looking to buy their stuff, but they apparently will be having a 20% off sitewide black Friday sale per an email I just received. They do have a nice front Wilwood BBK that I didn't know they offered.
BLACK FRIDAY 20% off Sale
Techno Toy Tuning
Our First EVER Black Friday SALE.
Use code BLACKFRIDAY for 20% off EVERYTHING!
Valid Thursday Nov, 22nd thru Monday Nov, 26th
If i didnt waste my money on a un needed transmission then i wouldve had some techno toy tuning coils right now!!!
Sent from my SM-G928V using Tapatalk
I have the JK Wilwood kit. Works amazing!
Which do you think is better for braking performance, the Z32/MPV or the wilwood kit?
I'd assume the wilwoods are lighter.
Can't go wrong with any of them. The biggest key is pad compound for pads matching your application, and keeping the system cool if you do end up pushing them to that point.
If performance is comparable, and the Z32/MPV setup is way cheaper I'll just go with that and add some brake ducts. I don't plan on tracking it when I'm done as of right now.
I do think I will grab some of the coilovers though. Sadly you have to ship your strut casing cores to them for the conversion, but such is life.
Which part exactly is the strut casing core?
You could buy the weld on kit and do it yourself, if you read the description you're getting the same kyb's the rest of us have been using for years.
https://technotoytuning.com/toyota/ma60/weld-front-coilover-kit-ma60-supra
I'm personally really eyeballing the rear coilovers, tired of messing with spring spacers to get the height where i want it...
https://technotoytuning.com/toyota/ma60/rear-coilover-conversion-ma60-supra
I also haven't seen any reviews of the newly upgraded steering knuckles, or really anyone talking about if the steering reaction increase is reasonable. THe adjustable ackerman isn't so much a concern for me, but cool that it can be done.
https://technotoytuning.com/toyota/ma60/super-evolved-knuckles-outer-tie-rods-just-about-every-old-school-toyota
Rear Coils require some shock tower reinforcement don't they?
I'm personally not comfortable with my welding level to weld my own front coilovers. I'll be doing the rear camber mod eventually but that's a different ballgame I feel.
Hmmm interesting. The reduced weight of the new arms is a nice feature, the ma6 ones are definitely heavier then stock. Curious how much the geometry varies from those too. Their standard arms are pretty good, but even the furtherest out hole on those is about all you would want for a streetable ma6x.
Super stoked about their new Big Brake Kit! You guys are on crack. Yes rotor size is almost exactly the same as the z32 rotors, but the pedestrian MPV calipers are bleh and way heavier then these sexy monoblocks! Also, pad selection! I'll take pad selection for race calipers over minivan calipers any day. And the z32 rotors are designed as over hub rotors so they are SUPER heavy compared to the stock setup. This T3 kit is probably about the same as stock. Would like to know if the caliper adapters are Billet Steel or Aluminum though. Anyways, if I hadn't already figure out an NSX rotor with z32 Caliper combo that pretty much nets exactly the same rotor size and placement as this kit and similar 15 inch wheel compatibility, I would have been all over this. This is a fantastic off the shelf option for anyone with similar priorities to myself. Its also made to appeal to peeps with smaller Toys that have adapted ma6 strut casings. Man, I've recycled so many of those over the years, I bet they are going to mega shoot up in value now.
Texas, it isn't actually the welding that's the tricky part with the front coil overs, its cutting the tubes down so they are perfectly square that's really hard. Next time I do a set, I think I will take the casings to a shop with a proper metal reciprocating saw. My stupid chop saw is fine for exhaust work, but it doesn't cut things square enough to shorten strut tubes nicely. There are some other intricacies with setting up the sleeves and such nicely too of course. Getting T3 to do it isn't a bad idea, their completed conversion is pretty slick.
IIRC isn't the swap z32 Calipers and MVP rotors, not the other way around?
So these extra strut casings on my parts car are gonna be going up in value? :p
You're right about cutting tubes down, I don't have a manner of cutting that accurate. I guess I could take it to the local machine shop but whatever.
Shipping two casings from VA to CA, 23 pounds give or take, $62 at UPS
I'm not really sure why most people would need to even cut the struts down. I have mine uncut and there is tons of room to bury the tire inside the flare
Discussion Starter #16
The T3 BBK would have been a lot cheaper if they went with a single piece rotor. They offer a kit for the 1st gen MK2 that uses one piece and the cost is a lot more manageable.
Aaron, you run 17s and are probably lowered like an inch. Once you loose 2+ inchs from a more extreme lower job, you absolutely need the travel back to keep off the bumpstops.
A little late for the black friday sale, but just if anyone else was looking at the coilovers. They say you have to ship your strut casings in for the conversion, but what isn't mentioned is that there is a built-in core charge. So when your struts get there, they refund you $100.
Of course it cost me like $60 to ship it there, so I only save $40, but if you live closer you'd save a bit more. Just some food for thought when you're pricing it out.
Discussion Starter #19
T3 Black Friday is currently back on in case anyone was interested in any items.
"Our 2019 Black Friday Sale is now live!
Save 20% off of your order at technotoytuning.com with coupon code SECRETWEAPON
This years Black Friday Sale will run through December 2nd so take advantage of the huge discount now!"
I'm just gonna say that last year the delays were huge, so don't buy expecting fast turnaround. They may be faster this year, who knows. They still took care of me in the end of course, great company to deal with.
1 - 20 of 21 Posts
