I installed a newer cylinder head in the spring for one that was barely shaved to keep compression as low as possible for a turbo upgrade...well, I adjusted the distributor with an inductive timing light till i found the crank mark and lined it up to ~ 13 degrees advance..( and had turned it almost fully clockwise- 5mge)
It bogged alot.barely made 4.5k on the tach ..ran like shit since then
I thought I couldnt tune this Split Sec signal conditioner, but instead found out it was me.
yesterday while stopping many times on I95 --- I started to pull back on the advance..a little better.. hmm. turn it Counter Clockwise a little more.. better still,..eventually i ended up turning it almost the full movement that adjustment slot would allow (C.C.) and now I am peeling out, laying rubber like crazy..hauling pretty good ass!! and I dont hear any pinging or knocking..
But when I got home and hooked up the timing light, and used the jumper to disable the advance i dont see a mark anywhere.
I am stumped.. and have no idea where the timing is set.
what could be happenning?
Which direction does the rotor button turn?
