1 - 13 of 13 Posts
The throttle cable on my supra snapped today and i was wondering what i can do? Can u buy just the cable and not the rubber tubing thats around the cable. And also if i did buy just the cable how the hell am i gonna fix it...probably not that hard but Ive never had a throttle cable snap before so i dunno whats involved. I just want some more knowledge before i tackle this
It snapped at the exposed part about 3 inches from where it connects to the throttle on the engine
No, its all one piece. You're best bet is probably used or new Toyota (try Jeff Watson 1-800-327-2087). Not even sure if they are still available.
If you end up going for a junkyard cable, make sure the ends aren't frayed at all, and make sure it slides easily, even after a little lubrication. When my cable went I had to sort through a couple to find a good one.
they are still available last time i checked.....the cable comes as one piece....
Discussion Starter #5
What other cars throttle cables can be compatable with the supra, just in case there are none at the wreckers
Lube the throttle cable..........never thought of that one!
Excellent idea........I'm going outside to do that right now!!!!!!
What helps can never hurt!!
Discussion Starter #7
seriously i cant find one anywhere tried toyota the wreckers everything, is there any other engine that uses the same length cable??
Toyota Cressidas, 1982-1988. The older engines have a longer cable I believe, but it will still work. Ive used an 83 cable on my 85 car, which I'm still using now.
their only like 35 bucks from the dealer if i remember right, i replaced mine due to a lot of slack...
Just to buy a steel wire and I have change only the cable inside the rubber tubing and work very well now.
Check cross over on the part #s on Toyodiy.com
1 - 13 of 13 Posts
