well, I've racked my brain trying to figure out why my car is being such a pain in the butt....
it idles high(900-1000RPM) and with a studder every 0.5 to 2 seconds randomly.
I checked my plugs(NGKs) 3 weeks ago, and although they looked used they looked fine. I checked them again over the weekend and they look like I took the cake frosting to them, filed everything to a 45 degree angle, refrosted, and regapped them to 0.5 inches. needless to say there's now new plugs(Denso) in the car. so why now is the car running lean?
The TPS I checked, 3 times, I have a spare TPS, it checked fine (and exactly the same as the first TPS) and is installed on the car for giggles.
The ISC was checked, all three of the ones I have, they all seem fine.
new cap and rotor, wires are almost brand new(toyota)
I've been over the vacume system 3-4 times and can't find any leaks. new lines ~1 year ago.
O2 Sensor is less than 1 month old.
the timing is set to something rediculous because at 10 - 14 degrees the engine chokes, hesitates, and has No power. (distributor 1 tooth off?) I "Know" the timing belt is right.
Injectors I haven't fooled with yet. Check connector doesn't work.
I'm sure I've forgotten some things I've already tried, but please, throw all the ideas to guys can think of.
TIA,
Mike
TIA,
Mike
