The link was above to my photobucket.
http://s304.photobucket.com/user/gre...y/1985 Supra
I can add some more details pics later. Maybe this weekend so check back in a couple days.
You can see some of what I did in the pics. I do have some customer motor mounts, so fitment will depend on where your engine is placed. There is a smaller gap close to the rack, but the dents/scratches in my pics are from squeezing it in and out so many times when I was fitting it all up.
I'm running the LT1 power steering pump and the high pressure braided lines and steel fittings.
There was a steel fitting that was hard to find to make the rack power and return lines to a -AN line.
Borgeson Universal Company P/N 925121 - Steering Box Adapters 16MM X 1.5 to -6AN. You'll need 2 and I think they come in pairs.
When flipping the 1/2 rack, the lines go through the cross member. Just undo the 4 bolts and twist. Obviously i had to drill two holes for the lines and fluid will leak out. As long as you line up the holes, it's fine. I initially drove the car without any operation problems, however, the steel lines I flared to go straight through to the cross memeber leaks. I think I did the wrong flare, or didn't tighten it down well enough. Since it's now IN the rack, its hard to get at. I'll have to cut an access hole, tighten/redo it and then weld it back up.
Does anyone know the flare and threads in the rack for these 2 middle rack lines?
I haven't had time to fix it, so the power steering pump just runs in a loop for now and I capped the rack at the power and return lines.
Driving it like this isn't bad which is why I haven't fixed it yet.
Drives like a V8 F-body w/o the powersteering.
Yes I understand that the holes in the cross member are taking out strength. however, they are not that large and as long as you are drilling circle holes instead of cutting out square sections, it's not an issue.
I'll probably weld in some extra bracing on the cross-member and a strut tower brace can't hurt with the extra weight in the front.
If you want a specific pic, let me know.
