1 - 20 of 24 Posts
I have noticed a few different styles of metal louvers around and I saw a set for sale locally that was different than the ones I had so I picked them up for S's and G's.
I am probably going to stick with the ones that were "TOYOTA" badged because the last louver sits a little lower and looks better with my wing in my opinion.
I think Chastain also made the Toyota badged louvers but I will be referencing them as two different brands in this post, identified by their stickers.
The Toyota set weighs about 8.5 lbs, has 7 louvers with a rounded end curve and 6 side vents.
The Chastain set weighs about 11 lbs, has 8 louvers with a sharp end curve and 7 side vents.
Here are some comparison pics.
Toyota:
Chastain:
Toyota:
Chastain:
Toyota:
Chastain:
Toyota:
Chastain:
Personally, I think the sharp edges on the Chastain make it look cleaner, though it might also have something to do with the paint.
You got it to fit well with the double spoiler :thumbsup: ...here's a shot of mine sans spoiler
whoa... wait... those fit with the double spoiler?!?
In my opinion, those louvers were made with the intention to use them with the double spoiler. without the spoiler the distance between the lower louver end and the trunk lid is much to big. should be the same distance as the other louver fins and thats the case when used with a double spoiler.
Now that I see them, I agree. I just had it in my mind for some reason that you couldn't have both.
Sent from my C5155 using Tapatalk
Discussion Starter #9
Toyota ones are definitely the better looking ones
With the '85 wing I agree. I would have a lot harder time deciding if it was without wing.
Really cool to have the differences posted in pictures on the same car!
Thanks for taking the time to do this! :thumbsup:
No prob! Anything on the Supra is a labor of love. I was curious to see the difference so I figured others might be too.
They weren't made to work together. It takes some work. The lower inside corners of the wing have to be cut a little bit and the mounting brackets from the louvers have to come off. Both sets of louvers required the exact same modifications to install.
I really like them both. I had to buy the second set to see them both on the car to decide. They would both benefit from some fresh paint, which is on the to-do list.
I don't think so. They take some work to make them fit together and when mounted with the wing the rear wiper will hit them once it gets about 1/2 way up so I can't use it anymore. I think the rear wiper is why they sit so high when mounted with standard brackets.
Discussion Starter #10
To expand on this a bit more, here are a few pics of the louvers that actually are made to fit with an '85 wing. Pics and car belong to Jake Foster "ABQMK2". They look amazing but I have yet to see a set for sale anywhere.
I have both and a Plastic rear louver as well. The Toyota one sits the best, but the bracketry looks like shit. The Chastain one I have was NOS, I installed it with the slip in brackets and it was a cleaner install. But It sat way too high in the back for my liking. I was only able to tolerate it with the Foha wing I had to kinda close the gap.
I have 2 rear metal louvers with the mounting brackets that slide under the window seal. Mine look totally different then the ones in the pictures, as mine don't have the holes on the sides.
Maybe a different manufacturer. I was trying to get my hands on a metal louver made by Kobel but I couldnt strike a deal with the guy that pulled it off a junk car since he thought it was gold or soemthing.
Discussion Starter #14
The Toyota ones had bolt on brackets, the Chastain ones had slide-ins. Post some pics if you can. I didn't realize there were so many metal styles.
Haha. Yeah I have seen a few "gold" sets around too. Funny how they still paint them black when they're made out of gold. ;)
I wanted to fix them up myself but I wanted to weld them up a bit. I don't have a welding machine though and those are so expensive :/ looks like I'll just take it to a body shop, thanks for the reply, gamble.
I'm not sure which one I have... haven't looked at it in a while... but I'm pretty sure I've misplaced the hardware...
Any chance U could U post pics of the brackets /mounting hardware?? as I'm likely gonna have to replicate them myself when I eventually go to put louvre on a car...
No spectacular hurry... but if U ...(or anyone else can) that would b appreciated...
Thanx,
1 - 20 of 24 Posts
