1 - 18 of 18 Posts
As in the subject, please post commonly purchased OE parts with their Toyota part numbers. If you have the *list price* (the non-discounted price) as well, please include this.
I'll round up my receipts when I'm back in town and make a big post.
Regards,
Jimi B
part #s and pieces
Door belt mouldings
#75710-14160 $105.72 @ Dealerships
#75720-14160 $105.72
1/4 Glass mouldings
#75671-14080 $ 70.42
#75672-14080 $ 70.42
Shift nob (blue) So specify color you desire.
#33504-24020-04 $88.60 @ Dealership
Shift boot
#58808-14100-04 $40.64
Console Lid
#58905-24010-04 $81.48
Heres a few that I had written down. I am looking for as much as I can find :)
Danny,
The interior part numbers that you listed.
More than likely, the interior part numbers will be the same, it's the last 2 digits that you will need to look at, those signify the colors. For those that are newbies, here's a review of the color numbers that would be found in the EPC (assuming that you have a US spec car).
01 = Black.
02 = Terra Cotta.
04 = Blue.
12 = Maroon.
I still have a bunch of receipts lying around @ my place, along w/ a few misc parts. Will have to round them up & bring them in, after I return from my trip next week.
BTW, Can one of the Admin's also make this item a Sticky????
Rubber boot for headlight knob
Mazda part number NA01-51-699. I paid $17.96 in Oct. '01. This is the part number for the rubber boot that goes over each of the knobs under the hood that you use to raise the headlights manually. You can't buy them from Toyota - for some reason they come with the control itself.
Theres a database on the Yahoogroups site for this. Ill add whatever shows up here to the database, but it may be easier to find things there.
Just something to think about...
What happens when/if Yahoogroups ever goes away or starts charging some sort of fee for it's use. I mean, all they need to do is so much as hiccup, and all that data is gone -- forever.
However...
I back up the CS.com forum database every Monday morning before I start working. That includes all the members, the forum format & theme and every single post up until the time I do the backup. I may step this up to twice a week, because of how busy the forum gets.
[edit: by the way, I just looked at the backup file - 139 mb]
Not flaming you by any means Wesley...but you might want to consider this. :shock:
More items
Heres some stuff I thought I grab from the FAQ section. I just realized that's where I got the other stuff from :lol:
Headunit Stuff
METRA wiring harness #70-1398 $10
Single DIN, Toyota Factory Pocket $ ?
(below the headunit) #16010
Non-Toyota OEM but helpful maybe
K&N drop-in-replacement #E-2487 $35
K&N Cone Filter to AFM #RU-2710 $50
Toyota SST on engine
Camshaft Timing Pulley SST#09278-54012 $ ?
Crankshaft Pulley SST#09213-70010 (not sure if you need 1 or both)
(bolt removal) +SST#09330-00021 $ ?
Crankshaft Puller SST#09213-31021 $ ?
Crankshaft Timing SST#09308-10010 $ ?
Pulley Puller
Thanks for the color codes Chris :wink:
Just a few toyota part numbers and list prices to add to the list:
Battery Clamp
74404-14260 $17.93
Oxygen Sensor
89465-29076 $111.15
Camshaft Gasket (under cam towers)
11117-43030 $33.12
11118-43030 $33.12
Cylinder Gasket (top of cam towers)
11213-43020 $12.10
Turn Swich Assy.
84310-14780 $231.40
Shift Boot Cover (leather looking material)
58808-14100-01 $50.12 (black)
Sun Roof Weather Strip
63251-14020 $46.53
Rocker Moulding
75850-19155 $126.62
75860-19145 $126.62
Belt Moulding (all the way around the car)
75612-14040 $31.45
75611-14060 $31.45
75652-14090 $35.26
75651-14120 $35.26
75624-14030 $37.59
75623-14030 $37.59
75653-14100 $45.51
75654-14090 $45.51
75732-14100 $87.36
75731-14120 $87.36
Console Door Assy.
58905-24010-04 $101.00 (blue)
TRD Shift knob (from tompson toyota)
00602-36303-000 $76.41
Still have one more parts order on the way so more part numbers will follow
Found a few parts that I have lying around. Don't have the prices.
(edit) 10-17-04. Just recently rediscovered my "Do-it-yourself-Pocket-Catalog" Brochure for the Supra that you used to be able to pickup from the Toyota Parts Dept from least 2 years ago, so more parts/part#'s have been added. Don't know if they have any more for our Supra's, since they been discontinued.
Radiator Cap
16401-36011
Thermostat
90916-03078
Rear Crank Seal (Toyota calls the crank seals "motor" seals)
90311-8001
Front Tranny Seal for the W58
90311-30115
Spark Plug Wire Set, 82 (Sumitomo wires)
90919-21311
Spark Plug Wire Set, 83 - 85 (Sumitomo wires)
90919-21317
TRD Spark Plug Wire Set (Yazaki wires, discontinued)
90919-MZ151
Distributor Cap 82 - 84
19101-70011
Distributor Cap 85 - 86
19101-43190
Distributor Rotor 82
19102-43060
Distributor Rotor 83 - 85
19102-43110
Oil Pressure Guage Sending Unit
83520-14023
Oil Filter (old part#)
08922-02011
Oil Filter (new part#)
90915-YZZB1
TRD Oil Filter
90915-SP020
Drop in Air Filter
17801-41110
Fuel Filter
23300-49065
Gas Cap 82 - 83
77310-12100
Gas Cap 84 - 86
77310-16011
EFI Injector Cleaner
08813-00080
DOT3 Brake Fluid
00475-IBF03
Brake Pads, Front
04456-14061
Brake Pads, Rear
04466-14060
Rear Swaybar Bushing
48815-14050
End Link Bushing to Rear Swaybar
90385-11021
End Link Bushing to Rear Control Arm
48817-12010
"Toyota Red" Antifreeze
00272-1LLAC-01
5MGE Head Gasket
11115-43030
85/86 Ignition/Door Key (NOT the Valet key)
90999-00105
Misc Stuff
Liquid Car Wash Soap
88608-0314
Cleaner/Polish
88608-0311
Aluminum Wheel Polish
00289-1AC00
Will keep adding as I go along.
· Administrator
Since I'm extremely bored tonight.....
89466-20020-83 02 sensor gasket $8.10
90917-06041 Exhuast gasket (?) $8.84
69206-14061-01 L black interior door handle $40.08 discontinued
69205-14061-01 R black interior door handle $40.62 discontinued
90942-02052 Toyota truck wheel stud (longer) $7.13 each :shock:
88320-01011-84 5M remaned AC compressor $328.17
88470-14010 AC dryer $38.22
88461-14010 AC condensor $248.78
88714-14700 AC suction hose $44.09
88711-14460 AC discharge hose $61.31
88718-14540 AC clamp under the battery $1.62 bought the last one
88718-14530 the other AC clamp under the battery $.80 ditto
48609-22070 strut mounting plate $79.28
90303-22049 white fiber seal under strut plate $3.60
48068-29065 R front suspension arm $166
48069-29065 R front suspension arm $166
22270-43030 TB gasket $2.82
11328-43030 gasket behind upper rear TC to head $3.98
19101-43190 dist cap $14.48
19102-43110 dist rotor $5.54
90919-01115 plat spark plug $9.72 each
99367-20920-83 alt fan belt late 5M $21.56
90916-02104-83 5M PS v-belt $10.20
99332-00975-83 5M AC fan belt $9.92
16572-43011 rad hose $29.32
16571-43010 rad hose $20.62
11213-43020 5M valve cover gasket IIRC $11.20
04111-43050 late 5M engine gasket kit $304.64
16100-49656-77 water pump $66.25
13568-49055 T-belt $38.58
90916-03078 t-stat $10.22
12262-43020 crank vent hose to valve cover $43.03
25628-43060 gasket (EGR IIRC) $6.23
23293-43030 gasket cold start injector $2.14
22278-42010 gasket ISC valve $1.94
2330-49065 fuel filter $30.18
31210-14160 7MGE pressure plate $96.56
90363-40022-77 throwout bearing $32.41
90363-12022-77 pilot bearing
31520-14160-84 remaned clutch disc 7MGE $73.93
90311-38032 w58 rear trans seal IIRC $7.97
27060-42030 remaned 80A 7MGTE alternator $338.12
25620-43110 EGR valve late 5M $170.19
13505-43010 Tbelt tensioner $102.57
81521-14291 L 84+ corner lamp $46.89
81511-14291 R 84+ corner lamp $46.89
90179-18001 rear diff pinion nut $4.43
90311-38010 diff pinion seal $12.52
41231-22010 diff pinion crush sleeve $11.35
90366-35023 pinion bearing $59.55
90366-30078 other pinion bearing $30.47
41182-22011 rear diff cover gasket $7.69
13103-43061 5M domed piston +.5mm $49.78 each
11071-43010-XX bearing $16.67
11701-43010-XX main bearing (XX is bearing #) $15.54 each
13041-42010-XX rod bearing $7.85
11011-43010 standard thrust bearing set $38.84
15100-43020 5M oil pump $280.47
13013-42060 piston ring set + .5mm 189.23
96411-44000 exp plug $3.89 7 req.
96412-43500 another exp plug $2.54 1 req
43514-22020-86 front hub grease cap $7.16 each
90919-02154 85+ igntion coil $81.05
89452-20060 85+ TPS sensor $169.05
17345-43020 hose from PS idle up valve to PS metal hose $8.75
96132-30400 clip for above $1.14
90999-00105 Toyota blank key small head
74404-14260 battery clamp bar $16.42
74451-14010 bolt hook for above $2.86
86336-14350 antenna mast $32.78
86327-22211 antenna cable with spool $15.60
00295-00102 tube of FIPG $26.34 (good ^&** eh)
23291-41010 rubber grommet under injector IIRC $4.19
17881-43021 rubber elbow hose on intake pipe over exhaust valve cover $99.66
16361-41090 5M fan blade $82.08
82122-14360 negative battery cable $61.16
90982-02260 postive battery cable ? $26.16
90982-05030 battery terminal $13.84
25870-43030 EGR vac modulator $67.32
45535-24010 PS end rack boot $34.10
25627-43110 $3.78 &
25628-43060 $7.28 EGR gaskets
58905-24010-01 black center armrest $112.12
17173-43040 Ex manifold gasket $33.54
90917-06039 exhaust manifold gasket round ones $4.16
88410-14090 AC clutch assy $185.38
11118-43030 cam tower gasket $29.95 11117-43030 other side
90311-38013 front cam seal $9.49
90301-56001 rear cam seal $2.77
57108-24010 corner susp brack strut rod bolts to $70.04
48674-19105 front strut rod bushings $40.38
04445-24012 PS rack rebuild kit $76.79
90368-31067 & 90368-19037-77 front wheel bearing $26.21 & $19.47
45460-29225 outer tie rod $78.01
90311-38011 wheel bearing seal IIRC $9.49
04479-14080 rear caliper rebuilt kit both sides $21.70
48257-22030 $25.24
48258-22050 $11.26
48258-22041 $11.26
48257-22030 $25.24 rear spring insulators ^
48725-22030 $29.72
48725-22040 $25.24 rear control arm bushings ^
04948-14050 rear brake spring kit $20.48
53341-14041 hood blanket $211.80
75996-14120-01 black "Supra" decal $144.88
85035-14260 headlight squirter nozzle $35.30
85035-14300 windshield squirter nozzle $18.89
75531-14020 front emblem $47.47
69685-12010 gasket under hatch lock $2.8
54125-14011 R protector in front of HL $59.05
54126-14011 L "
75534-14130 L side windshield moulding $50.51
75533-14160 R side windshield moulding $50.51
75553-14180 L front drip rail moulding $76.40
75554-14180 R front drip rail moulding $76.40
75552-14120 L rear drip rail moulding $91.60
75551-14120 L rear drip rail moulding $91.60
75596-14070 cover between the drip rails $5.04 each
75531-14120 Moulding over windshield $51.77
75308-14030 & 75307-14030 corner piece in 1/4 window $43.79
75672 (75671)-14080 moulding ? $76.39 each
75720 (75710)-14160 moulding ? $114.75 each
Did I mention I spent too much on this car? This is about half of what I have + about a zillion water hoses and gasket this and that.
Reactions: ddd228
A right side single arm was listed for over $80 from Toyota about 8 years ago. A drivers side double arm was listed at over $120. I know that ONE of the double arms (either the 82/83 arm or the 84/86 arm (YES there are 2 different designs), you cannot seperate the blade assembly from it, the other you can. So one of them is priced approriately. On my next visit to Toyota, I'll have to get the part numbers & prices for these items.
As a reminder to those of you that go to junkyards frequently... If you guys run into any rust free OE wiper arms & blades, SNAG THEM. Restoring them is pretty straight forward, but if they already have heavy amounts of rust on them, then it's going to be pretty challenging. So either restore the good ones & resell them to others who need to replace theirs (I've already sold 2 full sets to Leslie Grover & Nick (FWDsux), or be willing to pay the price for new OE Toyota ones.
· Administrator
Chris, are wiper arms that big of a deal?? There are tons of rust free ones around here.
Aaron,
Whoops, yeah up here in the PacNW (where it rains allot) they are sort of a big deal. 2 - 3 out of every 10 that I see in the junkyards up here, are in good condition w/ zero rust. The other 6 all have advance rust on them. I keep forgetting that the ones in the lower US don't have as much rust problems, due to the lack of rain & drier climate. :oops:
yes and around here i have yet to find any (let alone our cars). so far i have found one of our cars and i have checked probally 6 different junk yards. and the one car that is here, the whipers are gone. i think the previous owner had the same problem, because when i bought the car (7months ago), there were two way oversized whiper arms on it and i stupidly threw them out thinkin that i could find the rite ones. the worst thing is that i have to go to inspection soon, and i don't think it will pass without them. so if anyone knows someone looking to sell a set of them, please let me know,
thanks,
JR
I know where I can pick up a couple sets of the wipers, i'm about to pick them up and restore them just because they are so expensive. thanks for the info Cris
1 - 18 of 18 Posts
