1 - 14 of 14 Posts
Ok so i bought a different supra than the one i posted about in my introduction but this one has auto tranny probmlems as well. its an 85 ptype the charcoal-ish blue-ish color with a blue interior. Its in straight up awesome shape except im pretty sure the previous owner neutral slammed it one too many times.
When I drive it, I have to chase the peddle or else the tranny shakes the whole car violently and makes a rummbling sound. The rear is fine. The problem is only going forward. It goes into reverse fine.
Now for some infor on these transmissions: Do the a43 have the band style clutches that chryslers use? Or would it be cheaper just to replace the whole thing?
Thanks for putting up with me
preston
if u want to replace the whole tranny, i have one off a 84 p type with 125K. lmk
Ill let you know. Thanks!
The a43 series uses one way clutches(sprags) instead of bands. Take it to a shop, you may have other issues than trans. Could be bad trans/engine mounts, could be bad torque converter, could be bad transmission.
I thought about the torque converter and tranny mounts too, but i think its the cluster because it does shift but once it does it shakes. over 45 i can gun it and press into the peddle and its fine, just takes forever to get to 45 haha
Check your drive shaft to make sure its bolted down correctly
Thanks for the tip zank. I ll make sure to check the u joints
Real quick one, I saw the other thread on here about the guy who is also having autotrans problems and i didnt see the cressida listed as not compatible. If i find an auto cressy should i get the tranny from it?
A43DE
Four speed automatic with lockup torque converter and electronic controls
Applications:
* 1982-1987 Toyota Cressida
* 1983-1986 Celica Supra
* 1992-up Suzuki Sidekick (4L30E)
* 1992-1998 Volvo 960/S90 (AW 30-43LE)
get it from me, how much r u willing to pay for a tranny?
Biggest problem is the drive down to baltimore. Not sure which vehicle my old man would let me borrow for a day.
will fit in any trunk, is not heavy, lmk maybe we can meet half way if that works for u.
pm me a price.
Discussion Starter · #12 ·
Zupra, you gots mail
You still don't have your cable adjusted properly. Consider getting a firewall adjustable quadrant. You can get those at Summit. They have the entire clutch cable package. I put one in my nephew's 02 GT in one afternoon, so it's no big deal. The self adjustable quadrant is a POS.
__________________________________
Forex Automatic Trading
1 - 14 of 14 Posts
