1 - 8 of 8 Posts
Im considering shaving two opposing teeth off of my 24 tooth cam position sensor and telling my VEMS unit that it's a 12-1 crank position sensor.
Any problems forseen with this?
I have seen it before for MegaSquirt, and it is pretty much what I am doing also for the 6M when I get MegaSquirt attached to it. I can try to find the link and send it to you that I have for the 12-1 (24 teeth cut off 2 180 apart) and where to set the trigger points on what teeth.
that would be awesome, thanks. MS is a great way to go, I ran msns-e on my l28te before I went with a 7m.
What setup are you going with?
MS1 v3.0. Got it for a good deal. The only issue now is dealing with the tuning cable since MS is so picky.
Yeah, I ended up starting my custom dash so I could have a tuning comp with a serial port available at all times... Those Serial to USB adapters never worked for me with MS
after looking at the pdf, i'm stuck on trying to figure out which tooth is which... any ideas on how to identify the first tooth so I can identify which two I need to grind off?
Also, I'm assuming I need to wire this up as a VR sensor, correct?
1 - 8 of 8 Posts
