1 - 11 of 11 Posts
Hey everyone, repainting my trim is on the list of things to do next. Moldings, Window trims, and front bumper piece.
My car is a 3F2 Super Deep Red and my biggest debate is either going satin black or gloss black trim. If anyone has pictures of their fresh trim on a super deep red supra to show me and help decide, instead of only using my imagination, it would be greatly appreciated!
Really cant decide whether I wanna go gloss or satin, or maybe even satin black with a gloss clear coat? Not sure how that would turn out. So any advice, info and pics would be amazing! Thanks
P.S. it doesn't bother me at all that gloss black would not be a factory look, so restored to original is not a factor to me. I just want to know what will look best with SDR!
Satin black looks more stock. TOO shiny is not always good.
Besides, the other black on your SDR will look weird.
Discussion Starter #3
My mk2 is already noticeably modified (coilovers and 17 inch deep dish rims) so not looking stock is not an issue at all. And I'll be painting all the black pieces so the idea is that there will be no other black pieces left over to look weird and unmatched haha
But I agree, too shiny is not good. Thats why im hoping to see another SDR with gloss trim to make up my mind! Because I really dont know if gloss black with UV protected gloss clear coat is too shiny or not. Which is why im thinking about Satin black with gloss clear, kind of best of both worlds? not too shiny, not too flat
Gloss x 1 billion for the bumper halo which is factory. The window trim is more a half way between gloss and satin.
IMO you'll have a hard time with maintanence with satin colors unless they are cleared
The original trim was gloss black. Below is a photo of a brand new piece of windshield trim right out of the package. I've placed next to it caps from spray cans in gloss, satin and semi-flat from left to right for comparison (altho caps are never very accurate it was the best I could do on a moments notice). What's interesting is that the little corner pieces are not gloss, but rather I might call those a satin or maybe somewhere between a satin and semi-gloss. But all of the rest of the original trim was gloss when it was new. Hope that helps you to decide.
14858
I went ahead and did all of mine with SEM Trim Black Ultra in Satin. I think it looks really good and not out of place at all.
I wasn't aware the original trim was Gloss otherwise I probably would of done that. Still, I don't regret going with Satin at all.
Main thing is to prep everything really well. Be sure to use self-etching primer on metal pieces and adhesion promoter on plastic coated pieces.
The pieces that had most of the plastic coating chipping off of the metal I found was best to grind/sand all of the coating off to bare metal, make sure its somewhat smooth, then hit it with the etching primer then paint.
Also if there is any rust spots under the trim (I had some under the rear quarter window triangle trim piece) grind/sand all of the rust off, clean really well with some metal prep then coat with POR-15. It will get hidden again from the trim but the rest wont be eating at the metal overtime unseen!
Oh and mask off rubber seals obviously.
Hope this helps!
Black will be the best trim repaint idea if you haven't decided which one to consider. Make sure to keep us posted with this modification.
Hope this helps!
Any pics? I'm planning to paint my window trims also.
15138
15139
15140
15141
Here you guys go, hopefully this gives you an idea of the finish you can get with SEM Trim Black Ultra (Satin Finish).
Post some pics when you get it done! I'd like to see how others turn out
1 - 11 of 11 Posts
