1 - 7 of 7 Posts
When the car is cold I have trouble starting it. I only have this problem if the outside temp is around 45 or lower. I thought it was the cold start injector so I bought a new one $140 and put it in. It seems this still has not fixed my problem. Now keep in mind this is only a problem when the car has sat over night and cooled down after it starts and comes to temp it is fine for the remainder of the day. If it wasn't the cold start injector what could it be I need to figure this out soon bc it seems to be getting very cold rather quickly here in NJ
Thermo timing switch in thermostat housing?? Should be able to test it from the TSRM...
+1 on the timing switch (it is the brown one). I have seen quite a few of the timing sensors go bad, but none of the actual injectors go bad (unless it just needed cleaned).
Thanks guys ill check it out and let you know what happens. Well at least I wasted my money on the injector lol
guys I am having a lot of trouble finding this part it seems almost impossible. There are two sensors on the thermostat housing the one does coolant temp I can get that one but they can't seem to find any place that has the thermo sensor switch ANY SUGGESTIONS?
Are there any junk yards near you? Pretty much every Toyota from '72 to 90(something) has the exact same sensor you need.
Nice call Chris!!
1 - 7 of 7 Posts
